Marine 502 into 1984 GMC 2500 454
Supporting Member Army
It's also worth noting that a Gen VII BBC cam will also work just fine, but would change the firing order to an LS firing order. It would also use the factory roller setup with a cam retaining plate. Also, I'm pretty sure any BBC timing gear will work with or without the factory stepped nose setup. The stepped nose is to allow the retaining plate to be BEHIND where the timing gear would mount and has no effect. The factory EFI timing gear setups are different to account for the crank wheel needing to have the 4x reluctor on it. This limits it to only having room for a single row timing chain. If you are not running the EFI and therefore don't need the reluctor, you can run a standard BBC double roller timing setup on either roller or flat tappet cam setup.
x75x75x75
texas
BRIAN
C2500
wow, lotsa information to digest. the engine is 70 miles away so I can't get details very easy. The 72-year-old owner is a true gearhead, but it's been 10 years or more since he played with the 502 and its innards got scattered around a large shop full of mostly LS stuff and modified C6 Corvettes. He is trying to clean out the shop a bit so more parts may turn up, I would like to find the old roller cam stuff and see if it's any good. I also saw one iron BBC head that came from the engine I think.
The 454 in my current truck has a lot of new parts I installed when I replaced the cracked heads, like a new hydraulic cam kit that has 200 miles on it, already run in and working well. I think the clutch was recently installed, also I have an old Torker intake, holley 750 DP and so on. The truck worked well until it the bearing failure so I'm trying to re-use existing parts as much as possible.
As soon as my deposit check clears, I will grab some cash and go get the short block and anything else that looks related. We have found the oil pan, dampener, maybe starter and timing cover and other bits. Might have the engine by Sunday.
The iron heads that would have come off it are very good heads, but they will be rectangular port heads and not great at low RPM. I would still run them if you can get them. The big block cam will be very recognizable compared to an LS one. Look for the stepped nose, stock timing setup would likely also have the cam plate near it, it is a round plate with a large hole in the center that the cam nose sets in. It will have two "ears" on the sides with holes that you would put bolts in to hold it to the block. It also would have had the spider and dog bones that look like this:
It is a good setup that is very reliable, but is limited on how much lift you can run. If you are trying to run a cam with more than ~.650 lift, you can't use the factory dog bod and spider setup.
You can also just buy all the retaining hardware new for ~$125 https://www.summitracing.com/parts/...4aH8h_1Toq9vPKFERWnmMN7CA5WOnh7hoCez0QAvD_BwE
x75x75x75
texas
BRIAN
C2500
thanks for the photo Bextreme, now I know what bits to look for on various shelves in the owner's shop. Would the marine heads work well in a street car? I have a 427 in my Camaro with solid roller cam, steel crank and street-ported LS6 BBC heads that spins 6500 easy. For my GMC 2500, all I want is a solid truck engine, maybe some occasional towing, and regular gas tolerance.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Hey Brian, Welcome to the best forum for squares. I have messed with the 502 in a friends 71 Moute Carlo. loved that engine. IF....you get the block, I would STILL check the bottom tolerances, crank end play, use some plactigauge (.001-.003) the green one, to reaffirm that the mains and rods have the proper clearances. If you want to run the flat tappit cam, keep each lifter on the original lobe, and CHECK EACH ONE!!! and scoring, bad bad bad. Get every part the dude has, everything is expensive to buy new. The bottom end is four bolt, crank is forged has a wide forging line VS the narrow line on a cast crank. Cast cranks are still very strong, I used one in mt 489 build Here: https://www.gmsquarebody.com/threads/bbc-489-build.45389/
Pay attention to the small stuff, deburring, holes clean, tolerances. I am a machinist, and finished my career working on engines. That doesn't make me any better than anyoun else building an engine, except I know what to look for. Sounds like you are no stranger to BBC, however you mentioned a 750 Holly... had on on my 454, great, but may be limited on the 502. Chevelle headers will work on your setup, but the original cast exhaust arn't terrable. I always run headers....just my preference, and you can use them to your advantage to move the RPM around, add torque, (read smaller tubes, and long tubes.) You will need a stout trans, not sure which one you have. We all appreciate you being here, and some really smart guys have chimed in, were here to assist!
Shoote
florida
tim
Exterior dimensions are the same. The cylinder bore size is different.
x75x75x75
texas
BRIAN
C2500
wow, thanks to all for the sage wisdom. I am planning on picking up the short block tomorrow, and will have details soon.
Is this starting to sound like a build thread?
x75x75x75
texas
BRIAN
C2500
photos of the "mystery motor" I was so ignorant about
Craig Nedrow
Washington State
Craig
K10, K20, C20
Looks clean, lucky dog.
x75x75x75
texas
BRIAN
C2500
But wait, there's more. When I went to pick up the block, the owner said "you might want these too" and rolled out some brand new Merlin oval port heads. then he added "Springs are for roller cam". He also found some used valve train parts, like roller rockers and roller lifters. "Buy the heads and I will toss in the extra parts" he offers, and I tell him I only brought enough cash for the block. "You can owe me" he adds, "I know where your mother-in-law lives" - he's in her neighborhood. So it looks like I will run a roller cam if I can find a good one.
nvrenuf
Mobile, Al.
That could be a great score BUT make sure those aren’t too much head for what you’re doing.
Dang, you got away with a STEAL. Those world products merlin heads are a great cylinder head, especially for a street motor. I'd probably just throw a comp extreme energy roller cam in there and send it. The XR276HR-13 or XR270HR-13 is probably a good choice for a somewhat mild 502 for your square. You could also try calling a place like Delta Camshaft and see if they have a Gen VI stepped nose cam laying around they could grind for you specifically to your specifications.
1980gmc
