deleting parking brake lever
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
I haven't had time to do the parking brake cables on my square since the last big redo and it makes me cringe every time I park this thing in gear. Poor T56 :nono:
hope you have a pair or real wheel chocks handy. :confused::(
Turbo4whl
Downingtown, PA
Wayne
Jimmy
I'll add a story... My 3500 GMT800 wrecker with a car I just hooked up. Driving to the first stop sign. No brakes. Hydraulic booster leaking out the front flooded the master cylinder with power steering fluid. That oil over filled the brake fluid in the master cylinder, master cylinder seals failed.
That 5 speed had a real emergency drum brake on the drive shaft. Saved, I finished the tow, back safe going slow. Had to replace the master, booster and resealed the disc pistons.
xm20k
Girard, Ohio
The actor that played Chekov in the most recent Star Trek movies was killed when he was crushed by his own vehicle when the park mechanism in the transmission failed and pined him against a brick pillar.
Had the park/E brake been applied he would still be with us. :confused:
goldpack
Adirondacks, NY
Donnie
fiat jeep....made cheap.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Oh the humanity!
xm20k
Girard, Ohio
Adding the electronic Wilwood setup to mine is the next project in the works.
I bought their cables that are supposed to work with their internal drum parking brakes in my rear disc setup. If that doesn't work well, I'll be looking into the E setup as well
xm20k
Girard, Ohio
Mine don't have the drum assemblies they are aluminum centers so I have no choice but to use the electronic calipers.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
I suppose a surplus bucket off a front end loader and accompanied hydraulics could be mounted in place of a winch as an anchor of sorts.
It would certainly create conversations
Sad Sack
Nebraska
Goober
C15
If all else fails, then head to your local boat supplies store:
xm20k
Girard, Ohio
Started pulling up part numbers and realized it probably wouldn't apply to most here as I have a 9" with Dynalite pro rears. Mine requires several (3) different brackets than I currently have a set of backing/dust covers as well as the electronic parking/E brake caliper kit. Pricing things out it might be cheaper and easier to just buy a kit with the park/E brakes included in it. :rolleyes:
The kit I have.
The kit with the park/e brakes and associated hardware and brackets I would need.
straydog371
Army Law Enforcement Supporting Member
WNY
Kerry
kashwhite
