Dash bezel
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
im working with a 81 GMC. My delay wipers do some crazy things, sometimes the work, sometimes the don’t, sometimes the come on by themselves, sometimes the won’t shut off. My solution? I’m upgrading to a later wiper motor, steering column, etc with the delay on the turn signal. Easy enough, other than the big hole left in the dash from the factory wiper switch. My truck has no a/c, I would assume that is the only difference? I also need a bunch of the factory screws that hold the bezel in place. Pretty sure GM didn’t use drywall screws!! Thanks
rpcraft
Robert
LS 6.0 364 CID
the control for the delay is under the steering wheel in the later models so you will need the wiper motor and the pig tail for it.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have the motor, delay module, pigtail, etc, just need a decent dash bezel. My search continues!
rpcraft
Robert
LS 6.0 364 CID
Sounds like you are well on the way. Good luck!! And Happy Thanksgiving!
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Whaaaaat? You mean to tell me I'm not the only one who got a truck loaded with drywall screws? :(
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I don’t know, what year is your truck? Maybe GM ran out of the proper screws the day our trucks were built, and figured drywall screws are better than nothing.
I’m guessing that’s not the case!!
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The dash screws look a lot like drywall screws, just with smaller heads and a little shaped washer under them. Are you sure that's not them?
Moderator
Drywall screws must be the go-to for the average DIY types when they work on trucks. I had a Burb that was chock full of them.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
There were a few of the proper screws, most of them were definitely drywall screws. I guess whatever works. I would prefer to have the proper screws when this goes back together.
kenn
detroit
ken
c10, k10
still need a bezel ? ac or no ac ?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I just noticed your reply, I did locate one. Thanks!!
NateP350
