Remove or not, clutch peddle under-dash spring, when upgrading 1984 Chevy c30 Pressure plate to diaphragm
Bkjmak
UT
Brad
c30
I have a 1984 c30 with a SM465 transmission.
I replaced the OEM clutch pressure plate with a diaphragm style and now my clutch peddle, sometimes, stays depressed.
I found this on Google:
"Yes, new diaphragm springs significantly affect the clutch pedal. Because diaphragm style clutches apply force differently than older coil-spring (B&B) designs, they often require you to remove or adjust the factory under-dash "over-center" assist spring. If you don't, the pedal may feel numb, fail to fully return, or cause constant wear on the throw-out bearing."
Has anyone removed their assist spring?
Bkjmak
UT
Brad
c30
I removed the assist spring and my problem went away. The assist spring was more powerful than the new diaphragm clutch, causing a clash between the two. The new diaphragm pressure plate requires less leg strength, so no assist is needed.
Moderator
That's good to know! It's not an issue I've come across yet.
duncan_schawalder
