Dang truck.. one thing leads to another..
SlickGTP
Houston, TX
It took a bit of hunting, but when I was installing the correct parts for my dual tank system, I found that valve on ebay. Don't think I found it anywhere else though...
Moderator Administrator
IIRC, I've seen the valve on Rock Auto before.
highdesertrange
kalifornia
mike
k30
if it is dripping out of the hose you showed. you need a new valve. internal leak. I hate those 6 port valves. highdesertranger
Konas new ride
Alberta
Gerald
It is the original valve.. so not bad.. but who knows how long the ole girl had the drip..
I found one on amazon.. going to see if he has two (spare)..
If she's just got a little drip, nothing some antibiotics can't fix !!! :grd:
Konas new ride
Alberta
Gerald
I see your in Ok... Can i come visit???
Stewzer55
Ohio
Stew
R30
Happy wife, happy life.
Konas new ride
Alberta
Gerald
Bah.. when she isin't at work our boy keeps her amused. She knows i need this truck safe and reliable. The boy will be riding in it with me. :happy107:
Yup, those are Sooner Girls. I actually think I have that same pic on my hdd. They had a My Space page.
Konas new ride
Alberta
Gerald
fugging truck.. seized in filler plug on the 14 bolt diff.. So now i have a empty rear diff all sealed up..
Heat !!! Large Crescent with cheater pipe out the left or right side. Like a 4ft fence post. Once it moves 1/8 turn, you can take the cheater off and go to town.
Moderator
Worst case, fill a big ziplock bag with lube and stuff it in there, then put the cover back on.
Konas new ride
Alberta
Gerald
I figure i have two ways to go..
1 weld a nut to the filler plug and the heat should break it loose and toss my big ratchet on it and giver..
2 take the cover off and weld in a filler plug at the right height.. But either one is extra work and this ole truck is one step forward and two steps back for everything.
Konas new ride
Alberta
Gerald
Well it seems i am married to a smart ass.. 'my wife says to me.. Swap out the rear end..
yes she knows the amount of work that is... She walked away laughing.. :idiot:
Brianall
