Couple questions.
Pinski1015
Mishawaka indiana
mark
N/A
N/A
N/A
To do a 1 ton swap on a K10 (D60 front-14 Bolt rear) Do the Spring perches need to be relocated to work with the K10 or is it a straight bolt in? I know a dually rear 14 bolt won't work but wasn't completely sure on other styles. I know there are two different spring sizes 52 and 56, but are there width differences in the springs that would prevent the use of 3/4 or 1 ton springs on a 1/2 ton?
Driver4r
Nebraska
Trevor
k10,c20
Direct bolt in.
nvrenuf
Mobile, Al.
A 3/4 ton 14 bolt will bolt in but spring perches and shock mounts will need to be moved on a 1 ton.
The rear ujoint on a 14 bolt is a 1350 on both whereas the K10 will have a 1310. You can use a conversion joint or have the driveshaft yoke changed.
The front is a direct bolt in with the exception of brake hoses, these may need to be changed.
alwaysbroken
