Core Support Mounting
Ken B
indiana
ken
I am working on putting my core support (81 chevy c10) back on with new hardware. I seem to be bottoming out on threads as I am putting it back together. Since everything was rusted solid when I dismantled I have no way of knowing. Should the core support be fully tight and unmoveable with just the 2 bolts holding it, or does some support come with the rest of the body attached.
Wondering if I got the wrong bolts from LMC
Turbo4whl
Downingtown, PA
Wayne
5/16" bolts and 8mm are about the same size. They will thread into a nut partway and stop. Check for the correct match.
Ken B
indiana
ken
so my question is ,,,,will the core support be solid as a stand alone ? or will it be fully threaded and still have some play?
Turbo4whl
Downingtown, PA
Wayne
The core support needs to be bolted to all the front end parts to stand strong. The bolts should tighten fully.
Ken B
indiana
ken
thanks. I am just mocking things up right now and didnt want to move forward.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
with the rubber mounts installed you will still have some wobble until the fenders lock it all together.
Ken B
indiana
ken
I went to a shorter bolt, so my threads didnt bottom out seems to be the answer.
Jonny B
england uk
jon
gmc c1500
Just bolted mine back on,it will flex back and forth due to rubber mounts,dont lock up tight til wings are attached and dont overtighten rubber mounts as id needs rubbers to be flexable not stiff.
Ken B
indiana
ken
thanks.
Raider L
Shreveport, LA
William
The rubber support mounts allow the frame to move under the radiator, to flex. The support bolts up tight to the fender forward attach points. You could look for some of the bolts from the original support and put them in a vise and hit them with a wire brush in a drill. The fender to radiator support bolts should have a little point on the end of the bolt, not blunt like regular bolt. You could look for some that came from the original support that are like that and just clean them up. They shouldn't be more than about 3/4" long.
When I was rebuilding my truck I took the truck body completely apart and took every bolt in the dismantlement process and wire brushed every bolt like I described, one of those round stiff wire brushes for rust removal. Not that mine were rusted but just to clean them up for repainting. Then repainted every bolt with a light coat of semi-gloss black paint.
Ken B
indiana
ken
appreciate the info. I think I was sent bolts that were too long. ran out of threads b4 it started to tighten up.
Michael Benardo
Vallejo, California
Michael
C 25
292 Cubes
Bolts should tighten all the way, but core support is partly supported by front sheet metal, so it will be movable until that is all back on.
that_orange_c10
