Coolant out overflow
Thedivingpirate
Christopher
k2500
My 77 runs great, but every time I shut her off she spits some coolant out of the coolant reservoir.
Replaced the rad cap with a new 16 pound safety cap. Old one looked pretty worn out.
She does not run hot at all.
She does have a puff of white smoke out the left tail pipe at start up.
NO coolant in the oil.
Coolant level in the reservoir is about 4 inches from the top.
The pic shows a huge spot..just changed out my daughters thermostat housing. The spot in red is all that spits out.
Whats the next thing to check out?
Thanks for your time
Preston
Mechanicsville VA
Preston
I would just keep an eye on it, may check your spark plugs on the bank that’s smoking could have a bad plug, wire or low compression on 1 cylinder. Has the truck been setting for a while? Are you loosing oil?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
the coolant level is about 2-1/2 inches from the bottom cold. if your 4 from the top cold your probably over filled
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
What Preston said. Check the plugs for discoloration. I had something like this happen with my 77 when i bought it 20 years ago. It gurgle coolant in to the coolant over flow tank. No oil in water and no water in oil. I did find a plug that had a green tint (green coolant) to it so I pulled that head. It took a while but I ended up finding a hair line crack in the combustion chamber.
Thedivingpirate
Christopher
k2500
not loosing any oil, I drive it everyday. I will pull the plugs this afternoon and check them out. Thanks
Thedivingpirate
Christopher
k2500
pulled all 4 plugs from the drivers side, side that has the puff of smoke. They seem fine to me. Wires are not damaged.
Madhorn
AR-Arkansas
Ken
Just an observation. Second plug is a lot cleaner than the other three. May be nothing, but it is.
Madhorn
AR-Arkansas
Ken
Just had a thought. Yes it hurt. Put one the dirty plugs in the cylinder the cleaner one was removed from and check it in a couple days and see if it changes.
JOD26
