Compete cab corner
ScottG
New Orleans
Scott
Sierra
Well this is my first post here. I'm finally getting to my truck.
Do they make a full cab corner panel? By full corner I mean from the top of the cab above the door, all the way to the bottom. I need to replace that entire panel. I have the famous rusted cab corners, but I also have some damage on the cab corner about even with the top of the bed. I was told that that make them but I cannot find one anywhere. Any info would be very helpful. Thank you
Just the lower corners. If the damage is too bad to fix, the metal needs harvested from a donor cab.
They sell a "tall cab corner" - it doesn't go up as high as you are looking for:
And they sell an extended cab corner - goes up to about bed rail level but doesn't include the actual cab corner itself:
Greybeard
Iowa-under a rock
Randy
75 something (maybe ???)
k10 and a 1/3
I'm having the same problem.
I got curious about fixing the rust on my truck which is pretty bad and I knew there was some bondo in various places on it so I got a screwdriver and hammer this morning and found this>
I guess the only solution is a 'remove your own' salvage yard. But the problem there is not owning a cordless cut-off saw. :blah:
MadOgre
NA
NA
NA
NA
NA
Those are only helpful if all your batteries don't die lol then your screwed again
Konas new ride
Alberta
Gerald
Milwaukee sawzall blades "the Torch" worth every penny. If you have a 18 volt cordless saw you can cut a whole bunch of body with one of those blades and one charge.
I get pretty good life and cuts out of the Home Depot Diablo 5" x .040 cut off blades. And those torch sawzall blades kick ass too I agree.
Greybeard
Iowa-under a rock
Randy
k10 and a 1/3
I do have a Dewalt sawzall 20Vmax lithium. I'm not impressed with the battery life. I think maybe I got a bad one. I can only get about 15-20 minutes of heavy cutting out of it. By heavy I mean trimming tree branches up to 6" in diameter with a demo blade. I bought the saw in Feb. It came with one 4ah battery. When I was working in construction I saw electricians and plumbers use one 18 volt battery for hours cutting metal. :shrug:
