Jawzjeep
Honk if parts fall off
- Jun 5, 2021
- Washington
- Joshua
- Suburban
Just now really trying to get this thing on the road. Drove it a mile down the road to get some gas. I pulled out in traffic kind of quick and it squawked and bogged for a couple of seconds and then came back around just fine but lit up the check engine light. Took it back to the house.
The codes I got were a 15 and a 34. The 15 is my CTS circuit but my book says a 34 is for a 1984- 1986 (differential pressure sensor) or for a 1987 (MAP sensor). So since mine's in 91 how does that apply?
My coolant temp wires recently came disconnected and I put them back together so I went to check those and they seem good. The ground is on a pretty rusty bolt on the intake so I cleaned that up and reattached it. While reattaching it I noticed that one of my wires that I connected from the CTS was disconnected. After cutting back the heat shrink I found that I didn't pinch down the connection on that side for whatever reason so I thought bam there's the fix. But no it wasn't.
Took it for a spin and everything seemed fine until I got on it kind of hard and it shifted. The check engine light came on and when I got home I tested it again and it still said coolant temp sensor circuit. So while I fiddle with that can somebody help me out with the 34?
