Clear dash lense
custodian
Catawba
William
5.3 LS, 350
Where's the best place to buy the clear plastic cover that covers the gauges for a 73 C10?
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
You can use a small buffer for headlight lenses, they polish up nicely.
Snoots
Roger
Jimmy Sierra
Yup. Use one of those 3M Headlight Polishing kits.
ali_c20
Austria
Alexander
C20, K5
Headlight polishing kit and 2 thin layers of clear coat ( there's a 2component in rattle cans special for plastic and acryl, etc). I use this for taillight lenses, they look like glass after this treatment and don't scratch that easy.
Submariner592
Wisconsin
Scott
C20 Custom Deluxe
I just bought mine from LMC. I really made it look better and it was an easy fix.
MikeB
North Texas
If it's scratched, you can use sandpaper starting with whatever gets the scratches out, such as 400 grit, and then transition to finer grits such as 1000, 1500, 2000, finishing up with rubbing and polishing compound. Sometimes all you need is the compounds. I've never seen one get cloudy or yellow like headlight covers. But sounds like that has happened to some folks here.
I've seen a bunch of them turn very yellow and cloudy. They are usually trucks that sat outside for a long time with a window down, or a door missing or something.
Hatchet54
Wyoming
Red
1500 Sierra Grande
I'm gonna try that headlight polishing kit trick. Anyone have a specific link or part no? Amazon has a metric ton of different kits.
Snoots
Roger
Jimmy Sierra
You can get the 3M kit at WallyMart.
custodian
Catawba
William
5.3 LS, 350
I used Mothers Nulens on it, came out pretty good. It was cloudy, now a whole lot clearer.
SMC2224
