Circuit 150 Splice Location?
87ChevyV20
Maine
Jason
V20
Can anyone tell me the location of the circuit 150 splice location?
And, is it the same as the ground bus bar near the parking brake?
Thanks!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
If this is the splice you’re looking for, it will be in each taillight harness. Find the ground screw connector, follow it towards the front of the truck.
What are you working on? The main dash harness is grounded to a 5/16 bolt at the right lower corner behind the dash.
87ChevyV20
Maine
Jason
V20
Oh, sorry.
I meant the one under the dash.
The more I look at this, the more circuit 150's I am finding.
87ChevyV20
Maine
Jason
V20
This one here.
Looks to be near the fuse block I guess?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The main dash ground is up behind the left corner of the dash. With the dash bezel out of the way it’s easy to see.
What are you trying to fix? If that main ground was bad, I don’t think anything would work. Definitely not the radio or dash lamps
87ChevyV20
Maine
Jason
V20
Yeah, wipers, radio and other stuff is inoperable.
87ChevyV20
Maine
Jason
V20
So, I found what was causing this issue.
It had to be either power or ground and I was thinking ground because there was a splice that had a few of the inoperable circuits.
Well, it was the power wire.
Someone had cut the accessory wire coming from the ignition switch.
Go figure, but now my radio plays static!
350 w/203
You must have it on a news station.
Or, you may have inadvertantly loosened the antenna wire.
87ChevyV20
Maine
Jason
V20
No, it has the windshield antenna.
The radio could be bad too.
It is quite rusty on top probably with all the vermin leaving presents.
87ChevyV20
Maine
Jason
V20
Or, it could be the connection to the windshield is rusted out.
Joglz
