cheapest window to replace
crewcab higgy
chula vista
tim
r3500
So I locked the keys in my truck today, I got them out with no window breaking. But after waiting AAA then trying for an hour it came out to be a 2 hour ordeal. This is the second time I've done this the first time it took about 5 hours total to get in. So if I did this again and I'm in the situation to not wait do open my truck what window is the best break. I figure a window company will always have rear glass then have to pay for install. Any door window I can junk yard and do my self.
Don5
West Virginia
Don
k15
Get a spare key made and put it in your wallet. Much cheaper than buying a window.
yevgenievich
Place
Name
Year
Model
Size
If truck has electric windows run the wire to under the truck, then can have another jumper wire hang on the frame. Not easy to spot, but can be used to jump to power wire to lower the window
Carb'ed Vortec 350
Hide-a-key boxes are cheap and can be hidden under the truck somewhere. Or as Don5 said, put a spare key in your wallet. Or zip tie or wire tie a key under the truck.
350runner
tx
Ceasar
vent
chengny
No need to break a window. Just use a screwdriver (or a pocketknife) to get behind the rear window seal and pop the entire window out (takes like 2 minutes). Then when you get home you can snap it back into place.
highdesertrange
kalifornia
mike
k30
what's wrong with a hide-a-key. should have one on every vehicle. highdesertranger
Brianall
