Ceiling mounted grab handle mounting points
saltdog
US
K20 Suburban
I'm looking to add ceiling mounted grab handles like these https://www.ebay.com/itm/297085982446 to my 83 Suburban which does not have any. Does anybody have photos of the mount points in the ceiling. Presume I'll need to weld something up there.
Find where you want to put them as long as it's double wall construction you could use rivnut plusnuts pull out strength is 1200lbs in a 1/4 plusnut .
saltdog
US
K20 Suburban
@Ricko1966 - Plusnuts are definitely good for this! But its been over 20 years since I've had the headliner out so not sure what's up there to mount Plusnuts into. Figured I'd need to add some metal first so was hoping someone has pics
xm20k
Girard, Ohio
The headliner should just be mounted in over the steel inner panel that most trucks have as a ceiling when there is no headliner unless they changed it at some point, never owned one that had a soft headliner.
saltdog
US
K20 Suburban
@xm20k-Suburbans don't have steel inner panels like pickups do
xm20k
Girard, Ohio
Seems they don't, didn't know that I've only owned C series trucks. They do however appear to have a double walled outer perimeter that could possibly be used to attach rivnuts too to mount the handles.
That's what I thought as well.
Camar068
Air Force Supporting Member
10 yrs Air Force
wasn't there a post about pillar column grips/pull bars?
lht205
Alabama
Luke
R1500 Suburban
I’m not sure about the front, my suburban didn’t have pulls but behind the headliner but in my 88 there are built in mounting points that you won’t see unless the headliner is out.
saltdog
US
K20 Suburban
Thanks @lht205 , I was hoping the mount points would be there when I yank the headliner
that_orange_c10
