Carb backfire under load
Huskerfan33
Nebraska
Owen
Hello, I have a 76 K20 with the 350. It has fairly new plug wires, plugs, distributor cap and rotor. It has bone stock internals, and I just put a fresh Edelbrock 1406 650 cfm on it. I had it running great and then all of the sudden while driving I noticed a lot of engine noise and backfires through the carb at high rpm/under load most during acceleration. I double checked timing, and it is at 8, vacuum is around 15, checked valve lash and adjusted accordingly, new fuel filter and pcv. I'm stumped on this issue. I assume it's not a carb issue because the carb is all but brand new and was running fine before. Any ideas on what else to check? it idles fine and runs on all 8 still.
350 w/203
I suspect a vacuum leak.
77Dmax
vt
Joe
Lean conditions under load will backfire through the carb. Put two jet sizes up in it and drive it
How long did you drive it with the new carbureator,before the problem appeared? Why did you change carbureators to begin with?
Sad Sack
Omaha, NE
Goober
C15
Edelbrock are notorious for needing calibration.
Huskerfan33
Nebraska
Owen
Update, Fuel pump must have been on its way out. While tinkering it quit pumping so i suspect it was weak causing a lean condition under load
Broton2
San Clemente
Ryder
I’m having a similar issue with my 76 K20, it’s got a new distributor, plugs, wires, and fuel pump. It starts to backfire out the top of the carb as soon as it’s under load. It idles and runs great but as soon as the secondaries go to kick in it pops like you wouldn’t believe. It’s got the OG quadrajet that’s been rebuilt. I just timed it and have been stumped on it for a couple days now.
ChuckN
Bellinham, WA
Chad
If it is a 1406, it is a 600 cam, but more importantly it is jetted conservatively and also, the accelerator pump nozzle is amongst the smallest Eddy uses. As @Ricko1966 stated though, if it was running fine and suddenly changed, then it could be something different.
If it was fine before and now is suddenly not, look for vacuum leaks. If is brand new install, and is backfiring, it’s easy enough to change the accelerator pump arm to the most aggressive setting (the most rearward slot).
Huskerfan33
Nebraska
Owen
I've still been chasing this issue. It was a sudden issue thats why i suspect its not the carb since it is a month old. I checked all the vacuum lines and hooked up a gauge and that is all good. I think there might be something off with something ignition related but i dont know where to start
Sad Sack
Omaha, NE
Goober
C15
For what it's worth, are ignition components up to snuff and have you tried swapping out the ignition module with a known good unit?
Also have you done a compression test on the cylinders? A burnt exhaust valve can cause backfiring.
And go Huskers!
Huskerfan33
Nebraska
Owen
And go Huskers!
Haven't tried swapping modules but that's the direction I'm heading! Compression is good so I might just throw in a whole new distributor since they arent too expensive.
xm20k
Girard, Ohio
Could be distributor module also check to see if the mechanical advance isn't sloppy and springs back and doesn't just flop around.
I'd look at the valve springs and also verify all the exhaust valves are opening approximately the same amount. I'm leaning to a valve spring. It happened suddenly,yes a module could go bad out of the blue one day but,they usually just die or if not just dead,dead soon after.
Wesley496
