Steppin Razor
- Apr 21, 2023
- Houston
- S
- C10 silverado
I've been working on my steering system as I've been able. Cannot seem to get the play out.
I have replaced:
Rag joint
Steering gearbox
Pitman Arm
Idler Arm
Tie rods
Upper Control Arms.
Rebuilt the power steering pump
I also had to replace the ignition rack and sector gear, which means going in through the steering wheel, and tightened those torx bolts. Replaced the bearings in that collar around the assembly as well.
I adjusted the steering box at the back and the pitman arm.
If I stand by the door with the hood up, I can see the steering shaft move when I turn the steering wheel within the play zone.
I'm starting to suspect that maybe the gearbox (Cardone) I got from RockAuto is not good. There doesn't seem to be enough adjustment range in the pitman arm adjuster. I hope it's not it because that's pretty mugh the highest priced and PITA-est thing to replace. Before I think about that, anyone have other ideas?
I have replaced:
Rag joint
Steering gearbox
Pitman Arm
Idler Arm
Tie rods
Upper Control Arms.
