camino wont start
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
If your pouring gas down the carb, it should pretty well try to start no matter how fast the motors cranking. Your getting fuel, no doubt, so it HAS to be ignition of some sort. Not sure where though... You don't have a hole in a piston do you lol
82eLCo77C10
JoMo
slade
Not that I know of. I have torn it apart. Like I said, it was my dads. So I'm starting in a mess...on a Chevy head, if you are looking from the front on #1 cyl. Does it go intake valve exhaust valve or the other way...
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Ignore my last post. Im fairly sure a SBC will run on 7 cylinders lol. Actually, Im sure theyd run on 6 if you had the right cylinders lol
82eLCo77C10
JoMo
slade
On the heads starting from outer side of #1 cyl. What way do the valve go. Intake exhaust or exhaust intake.
MrMarty51
Eastern Montana
Martin
E i i e e i i e
82eLCo77C10
JoMo
slade
Alright after a month of bein dumb. I got the camino running. It was out of time for sure. As soon as I got it to the tdc this time. (on the right compression stoke). It was about 45degrees out. I drop the distributor back in. Gor everything hooked back up and the wires tucked out of the way. Went to fire it up and bam. First turn of the key! Thank you guys for the help. It is much appreciated.
82eLCo77C10
JoMo
slade
Fin
82eLCo77C10
JoMo
slade
Dang thing wouldn't let me post my comment and now there is 3
82eLCo77C10
JoMo
slade
Another small question. Why are there small flames coming out of the top of the carb every do often? Is that from all the extra fluid I dumped in there when I was trying to get it to start?
IF you're getting small flames, that's a good sign that you are getting spark. But it means the timing is off. Timing is way far advanced.
So if backfiing out the exhaust at all too or just the intake?
82eLCo77C10
JoMo
slade
It was just the intake. I retarded the timing and they went away. Now she's running like a champ. I just gotta get some different valve covers. Those damn chrome ones always warp. It is leaking pretty good outta the valve cover on the header side of the passengers. Driver side sealed great. But that's an easy one. I'm just glad its up and running again.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Congrats!
Timing will get ya every time. Me and my grandpa couldn't get our VW going one time... turns out we somehow had the distributor 180* off... completely backwards lol
Cool, so now that it's running? When do we get to see pics of the El Co? You know they're kinda like trucks, and they're kinda square. :shrug: You can do a build thread in the Other Vehicles section.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
^^ Lol he makes a point! Maybe I need to post a pic of my El Camino and we can compare lol
82eLCo77C10
JoMo
slade
Yep, she's nothing special. I will have to figure out how to post pics from my phone. I would have no idea how to on here.
twzorek
