crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
To weld high-carbon steel, if that's what the studs are, and I think they are, you have to preheat them with oxy-acetylene to better than 200 degrees, then post-heat by sandbagging or heat blanket to keep the weld from cracking, then re-temper. I'm tellin ya, you'll be miles ahead of the game if you just get some grade-8 bolts, take loose the motor mount, jack the motor up as high as you need for clearance and bolt it in. Hell you could even do a couple 1" seam welds in places where you could cut them back out easily with a 4" angle grinder with a cut-off blade if you needed to. It would be better than those overheated studs breaking on the highway at 100 mph and crossing the median and killing a family and more than likely yourself. Just my $0.02, but don't take unnecessary chances on mission-critical parts.
