Bypassing ESC
ryan.johnson
Ryan
c10 lwb
I went to install a new hei distributor today and had the unpleasant experience of learning what electronic spark control is. I've already bought a HEI distributor and would like to install it, from what I've read I can just ignore the wire harness, my question is do I need to bridge the two pink wires that run from the esc module to the other pink wire?
Also when I discovered the esc I became suspicious if my truck actually was converted to a 350 engine as the p.o. said, so I spent far too much time searching for the vin.
I finally found the casting number on the drivers side (4010207- no 1 in the front like every numbers list I can find says). Is there any reason it wouldn't have the vin stamp on the front passenger side?
thanks for the help.
-Ryan
yevgenievich
Place
Name
Year
Model
Size
To remove esc and put new distributor in, all you should need to do is just plug hot to BAT terminal on the new distributor, nothing needs to connect to the esc module. As far as the block, it is possible to not have vin stamped on the front passenger if the block was either warranty block or replacement over the counter block. more than likely 4010207 really has a 1 in front of it, which should point to a 350
ryan.johnson
Ryan
c10 lwb
http://imgur.com/UeSv7xv
Heres a pic I got of the casting number.
Do I need to splice the two pink wires together that go to the cap or are they fine as is? They both go to the same connector.
Nope, you simply install the HEI dizzy... done. You can leave the ESC harness, cut it off, remove the whole thing or whatever you see fit.
alwaysbroken
