Bvllsh!t on craigslist.
Status
Not open for further replies.
Moderator Administrator
Pretty solid looking truck!
nxtlevl
Hutchinson,KS
Ed
I'm going to have to stop looking at this thread.......I've been seeing way too many vehicles that I "coulda" bought instead of this one........:roflbow:
I wonder how he put that Pontiac in there. Did he fab up some mounts, buy aftermarkets, or weld butcher some crap in? Not sure if you are aware, but I have a 68 Olds 455 that I want to put in a SB. I intend to use motor pads I got out of an 80 Model GMC that had the junky 5.7 350 Olds Diesel in it originally. Then was converted to Olds 350 Gas. So useing those motor pads, I can use Olds 455 mounts. Then build the Olds trans using the short threaded truck output shaft and have it just like a factory bolt in set up. It'll be a scootin mo fo and put this 84 C20 454/Turbo 400 to shame.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
http://houston.craigslist.org/ctd/2097031642.html
nice truck but not worth anywhere near $8K.
I think for 8k you could find a show quality classic or maybe something really bad ass to take to the strip. Sure my truck is a total piece of **** so I really shouldn't comment on others trucks but when someone thinks their truck is worth that much I cant hold back. Here's what I noticed just from pictures... I could only imagine what you could find looking at it in person.
Front bumper appears to be bent a little bit.
Bumper is missing 2 chrome bolts in front.
Its a less desirable long bed C10.
Front part of bed is all dinged and bent to ****.
Old ****** rear window rubber.
Missing lug nuts and even valve stem caps.
Door panel looks like its deteriorating.
Missing brake pedal rubber pad.
Gauge bezel looks like ****.
Upper radiator hose looks like a ****** dryer vent.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
And a 700r4 doesn't have a BOP bellhousing. I know there's adapter plates for that. I think Ken Keefer (Pontiac Dud) of Brooksville, Fl has motor mounts available.
Status
bvandrey
