Bvllsh!t on craigslist.
Stewzer55
Ohio
Stew
R30
I like that turbodiesel burb, it looks like its dying for a manual trans swap or an HRPC Super700R4 trans.
I've always wanted a Monte, this one here would be perfect. Out of my price range though :sad72:
http://richmond.craigslist.org/cto/4389786030.html
That's my favorite style Monte Right there. Heavy ass cars. I don't care for the 73 74 lard ass looking models, and they shrunk down again in the late 70's early 80's and I don't like those either. They did start looking good agian in the mid to late 80's in the G body.
I'm almost thinking about looking for me a Gen 5 G Body Elco. For all these trips I need to make to my dads to sell a rear end or transmission and it costing me $50 round trip, I'm thinking with a later model Elco I can make the same trip for $30-$35. But here I go talking about trying to get something better on mpg and I know damn good and well, I'd end up building a damn motor and trans for it for drag racing and shoot the pooch on the whole purpose. I've been fooling myself for several years now.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I've been looking into getting a MIG for some time now and finally have the means to do so. I'm looking for a machine that will let me learn without too steep of a learning curve but allow me to have some room to grow.
Mainly looking to weld tube and 1/4" steel.
With that being said,
http://losangeles.craigslist.org/lgb/tls/4406417306.html
anyone think $350 for a used Lincoln weld pak 155 is a good deal?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I would hold out for something different. While it is 230V machine, it doesn't have the gas solenoid. I'm not sure how much they run, or what the availability is, but I would hold out for one that is already setup for MIG instead of just Fluxcore. Fluxcore tends to burn hotter than MIG and is quite a bit messier spatter wise. If you are only looking to weld up to 1/4", a 110V welder is more portable (can run it anywhere that has 110V as opposed to fewer places having 230V). The Hobart Handler 140 can be had new for around $500, is already setup for Gas or Flux core, runs on 110V, and is just a very good all around welder. If you can find a lightly used one, that's what I would do.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Thanks Foamy. I'll take a look into those Hobarts. Apparently the conversion kits come with the gas solenoid as well and those are only about $200. So, the total would be roughly the same as a new Hobart. Plus, the garage is already wired for a couple 230v outlets. Don't really need it to be all that portable.
Sent from my IdeaTabA1000-F using Tapatalk
Oliver90_08
