Bvllsh!t on craigslist.
Status
Not open for further replies.
Moderator
Is it $2250 or $1750?? Can I get some more blurry pics?? ******* 1970's mobile home linoleum in the floor? WHY!?
http://huntington.craigslist.org/cto/3214012487.html
I've been looking at duallies lately and I think this one has potential but seeing the obvious ****-ups, I'm scared to see what else I would find!
Lol, that flooring is awesome! Why? Because it's southern OH and that's just how it's done :roflbow:
2 Wheel Drive Aluminum A833 4 speed OD anyone??? Trans Only, No shifter !!!
http://www.ebay.com/itm/170916452891?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Not for that kinda money. That's halfway to owning a T56.
Moderator Administrator
Moderator
****, there were 2 6 speed Z28s at the junkyard, unmolested...Trans are $200 each.
Get on it! You can make some cash with those! Selling price for a complete setup is $1100-$1500, depending on condition.
79K10
Sacramento,ca
Ryan
350/th350
I'd do it just for the $20 since you're interested in seeing what all is involved to convert to PL and PW. I can tell you, you'll have to get antoher main harness from a Silverado out of the junk yard. It's the one that will go from your fuse box to the under the dash with 2 plug-ins, one goes to the left door, one goes to the right door. Then the harnesses off your doors are routed thru the kick panel behind the glove box and under the instrument cluster, to this main harness that goes to the fuse block. A bit of a hassle, but it can be done. I'd suggest going to a Pull a Part type lot and pull one apart, then you'll KNOW what to expect and how to route the hanresses, but it should be all plug in and fairly easy to do. You'll have to pull your fuse block off the firewall to plug into the back of it though.
sounds like fun... lol.. thanks
http://austin.craigslist.org/pts/3272510052.html
Probably show up on the free stuff pretty soon...Or it will sit out there and rot. Never seen a wind deflector and roof rack on one though...
I wouldn't mind a wing for the back of my Burb to keep the dust and **** of it. I wouldn't mine a roof rack either. That would be handy for me when I got to pick up building materials for the house.
Status
certman
