Bulb contact cleaner
Doug13
Ringgold Geroiga
Doug
Surbanban
350c.i.
After cleaning up the circuit board as others have said to do with an eraser what was used to clean these up . Thanks in advanced.
Emory cloth or a points file.
You can use an eraser there too.
Doug13
Ringgold Geroiga
Doug
Surbanban
350c.i.
Ok fellas thanks . Hopefully these lights will work again soon.
Oh, and you can also "re-tension" those contacts. Just bend them out slightly to increase contact pressure on the printed circuit.
Camar068
10 yrs Air Force
small piece of scotch bright or 120 grit sandpaper for a light scuff to refresh the metal helps as well.
dob555
