Built sbc stumbling under load
gwandro
Red Bud, IL
Grayson
Scottsdale
I have a built sbc that I’m trying to get dial in. Running into a problem with it having a stumble/spuddering at high rpm under load. No problems when revving in neutral. Has done the same on 2 different carbs. It has an electric fuel pump. Maybe lose fuel pressure? Not really sure. Might look into getting a fuel pressure gauge and seeing what I get
Maybe an ignition misfire,that would my 1st check. Spray under hood with salt water after dark,power brake it and look for lightning under hood.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
What carb are you running? And what other carb did you try?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Usually an ignition issue. What's base and total timing?
Will it clear up above a certain rpm?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
I say misfire or vacuum leak causing a misfire
gwandro
Red Bud, IL
Grayson
Scottsdale
Holley at first then switched to edelbrok off another truck of mine that runs great
gwandro
Red Bud, IL
Grayson
Scottsdale
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Starts at 3800 in 2nd gear and 3000 if I’m on it in 3rd
Is it a fall on its face stumble or more like a misfire? Could be pinging.
We need to know your timing.
I've found that most off the shelf carbs are tuned pretty lean.
Vbb199
Salisbury NC
Vince
Seems like that rpm in 3rd might be indicative of the mechanical advance curve? Maybe too much timing total
xm20k
Girard, Ohio
Need more info
Is it a stock rebuild?
Is it a performance build ie. big came and/or high compression?
What distributor? HEI or aftermarket?
What size carb?
duncan_schawalder
