Brake Light
Scott91370
Burleson, Tx
Scott
Sierra1500
Out of the blue the brake light came on. Plenty of fluid, parking brake switch not sticking. Truck stops great.
If I unplug the wire on the proportioning valve the light goes off. Do this 'go bad'?
You can pull and test the switch. If the switch tests good,it's almost certain that the shuttle valve is not centered. That would mean you dont have enough pressure on one circuit of the brakes and a thorough brake inspection is needed.
Sad Sack
Nebraska
Goober
C15
What he said ^^^^^
Plug this into CoPilot and you'll get some ideas: On my 1985 GMC C1500, the brake light is on. If I unplug the wire on the proportioning valve the brake light goes off.
gofone
Pecos TX
Butch
R10
If it has ABS disconnect the ABS module , they had trouble with some of them
I don't think they had true ABS on any square. They had RWAL but it was mechanically controlled
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Make sure the park brake isn't on (or the pedal drooped down).
K
Chrispy
