- Apr 11, 2017
- kansas
- Rick
- c20
FWIW to any or all of you brakes used to have a residual pressure valve to maintain slight pressure in the lines. Part of the reason was it kept the seals in the wheel cylinders under pressure so they sealed even when you weren't on the brakes,this helped prevent air from getting drawn past the seals. Newer seal technology,this was supposedly eliminated. Still,if I had mystery low or spongy pedal I'd bleed and adjust my rear brakes.
