Bought a 1986 K10, truck died while driving today.
David Andrews
Barrie Ontario
350 SB
Hey folks, just bought my first square body truck and joined the forum. I'm 17 and also have a 1978 Corvette that I have worked on quite a bit so I have a decent understanding of 350 small blocks and decent idea of how to diagnose issues.
Today as I was driving the truck, it died on me. After that it would crank but wouldn't start. After cranking it a few times it started to crank very slowly. I tested the battery and have full power to the battery. Just over 12 volts. I checked the carb and its squirting fine I think. Sounds like it might be the starter and distributor?
Any help?
Just over 12 v is not a fully charged battery, so charge the battery. Check for 12 to the distributor with the key in the on position. If you have 12v there pull a plug wire and check for spark. Post results.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Did you test for spark?
Anything below 12.6v is technically low.
Edit: Richard beat me to it.
Dmack
Central OR
Dave
You checked for fuel, so next check for spark. The ignition modules are known weak points. You can pull a plug and ground it while cranking the engine.
My 83 did the same thing while I was rebuilding it. Always started fine, then one day nothing. Ignition module was dead. It is inside the distributor. I ended up buying an inline spark tester. They plug in between the plug wire and the plug and make it much easier to see spark , especially if you are working by yourself. Nice, bright flashing light if you have spark. Only about $7 at Oreillys.
And welcome.I
Edit, and I was slow too!
And welcome.I
Don't ground the plug wire hold it about 1/4 inch from something metal on the engine. Whatever is convienent.
80BrownK10
Greenwood, SC
Nate
Any help?
Just over 12 volts means the battery is about dead. Charge it up. Are you sure your alternator is charging?
Dmack
Central OR
Dave
Thanks for clarifying my post. I meant to say ground the plug while in the plug wire boot once pulled.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Is it spitting and sputtering? Or is it just straight cranking, no fire at all? Could still be fuel, but check for spark
You said it right. I read it wrong
If you haven't checked for spark yet here's an easy way. Clamp a spare plug gapped to about .080 into a jumper cable clamp the other end to ground pull a plug wire off a plug that is visible from the drivers door. Put it on the spark plug clamped in the jumper cable and crank while watching for spark
BryanC
USA
Bryan
C1500
While performing the test list above, take a moment to check the positive cable from the battery to the starter solenoid. I had an eyelet rust apart at the starter motor on my 73 C3500 and had to get towed home. Before the cable failed, the truck was harder to start when the engine was hot and I wasn't always getting 12V at the HEI distributor.
Newcman1
Tulsa
Bill
Chevy K10
I know this is an old thread but was wondering if you found the fix?
Original
