Bolting 5.3 to 700r4
tjw82c10
Los Lunas, NM, USA
Tyler
Hey everyone, as the title states im gonna keep my 700r4 and bolt it up to my 5.3. My question is when getting the motor into the engine bay and mounting it up will I have firewall clearance issues? Will i have to get an aftermarket crossmember for my transmission like a 4l60E? I wanna just use the stock one and bolt it that way but I dont want the motor slamming against the firewall. I was gonna use the dirty dingo mounts so i can adjust it.
Have you figured out how you're gonna hook up the TV cable on that 5.3? I have yet to see a good way to do it. Much easier to just put a matching 4L60/65/70E along with the engine. That way everything jives and works the way it should.
Tejas Steelworks engine mounts moves the engine up/forward so you can reuse a stock truck oil pan if you want. Their crossmember can be used for pretty much any transmission, you just position it where it needs to go and drill holes/bolt.
If you're hellbent on keeping the 700, get that Tejas crossmember. Take the motor back out, bolt the trans to it, drop the whole thing back in and see where it wants to live. Mark your holes and drill for the Xmember
Zelph
Nevada
Get the ORD LS mounts.
“These mounts place the back of the block in the stock location so you don't have to move your transmission, or if more firewall clearance is needed, we've added a forward position on our block-side mounts that shifts the drivetrain forward 3/4".
Camar068
Air Force Supporting Member
10 yrs Air Force
Should bolt right up. I used the dirty dingo mounts then mounted the trans to the crossmember and then adjusted the engine mount plates to that position.
tjw82c10
Los Lunas, NM, USA
Tyler
Thats awesome, I am keeping the 700r4 for the simplicity reasons and cost. I cant find any "good" 4l60es for a decent price that isnt "rebuilt" or beaten to **** and need a rebuild. Im gonna use the Pro Built kit which ive heard is pretty good and includes an instructional dvd. Any experience with it? Hows your 700 holding up?
Camar068
10 yrs Air Force
I don't have a 700r4. I've got a 4l60e that came with my 5.3. My understanding is the 4l60e is an electrically controlled 700r4.
tjw82c10
Los Lunas, NM, USA
Tyler
Oh yeah I’m going carbureted cause I get a discount on parts so the controller and Intake is only 800 bucks lol and I was gonna go with a Holley TBI later down the line for a vintage deal, but the intake comes with a TV cable adapter so it works out
NateP350
