body lift
coreys87
newyork
corey
v1500
Looking to do a 3 inch body lift on my 87 k10. Its the sm465 tranny 4 wd. Just curious how hard it would be to do. Biggest concern is the shifter. Do you extend it or what? Thanms
Swims350
Logan WV
none
it mounts in the trans it'd just be 3 inches shorter inside. I see no real reason why you'd need to extend it. Just reach down 3 inches lower.
as for the kit itself the bumpers and the gas tank is what I hate, hanging down not raised to match.
coreys87
newyork
corey
v1500
The front bumper i could make a bracket. Never thought about the gas tank tho!
IMHO, body lifts for these trucks are a waste... suspension lifts are cheap. A 1inch BL is OK since it provides extra clearance for other things, but doesn't screw up how everything works.
I agree. Maybe even a 2 inch wouldn't cause much grief, but I'd damn sure max it right there for a body lift at 2inch. Anymore, you need to start things like extending brake lines, shift linkages and geometry, move bumpers, fuel tanks, clutch line if hydraulic, clutch linkage if Z bar etc. :shitsweak:
marks86
Latham, NY
Mark
12v Cummins
not to hijack this thread but anyone know where to get a 1in body lift I couldnt seem to find anything smaller than two inch
Yeah, I was gonna say, think most 1 inch kits, guys pretty much make their own.
coreys87
newyork
corey
v1500
very interesting. thanks for all the info. looks like if 37's wont fit ill just go with the littlest lift i can get. thanks!
I thought ORD sells the 1" BL.
Or do a 4 or 6 inch suspension lift. You know there is a cheap way to do a 4inch lift using rear half ton springs up front. C4 has more details about that. That is what I may end up doing since I have plenty of half ton rear springs. Then a cheap block kit for the rears and there you go. I'd actually consider the cheap 4in suspension lift before I'd consider a body lift over 2 inches.
alwaysbroken
