Blinkers/Hazzards stop working when headlights turned on...
I do actually :waytogo: the expert on this will be Devs93. Let me get him in this thread.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
my flashers are not stock they are electrical ones. every light on the exterior is led. i wont need resistors. the side maker/parklight setup worked fine and alternated EXCEPT with the park/headlights on. were you saying that the alternating lights wouldnt work at all? cuz it worked for me with the headlights/ parklights off
They are only supposed to alternate when the park lights are on. If they are off then they flash the same pulse as the turns. Park lights on, they should alternate.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
oh i gotcha, i just assumed it still alternated
Devs93
Shelbyville ,IN
Deven
c1500
We are trying to figure out how to run LED's in the front turns and front side markers. LED's may screw up the alternating flash they have from factory setup, know what I mean G?
You can use resistors like stated above. I prefer using an led flasher to replace the oem one
Well that helps explain it.... :rolleyes:
Posted from mobile...
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
i have replaced the flashers and it doesnt work. do you think resistors would fix the alternating problem with the headlights on? otherwise im good
Devs93
Shelbyville ,IN
Deven
c1500
:lol: basically the since leds use such a low votage it cause the fast flash. im not sure what style flasher is on the square bodies. i would guess an ep36 like the 88-95s take. U can pick on up at autozone for like 8 bucks. the tip I can give on finding it is turn on the signal and track down the clicking :lol: guessing under the drivers dash behind the ebrake. the resistors also work great...I just dont wanna splice into anymore wiring than needed...They other issue that can sometimes occur with leds is the turn signals can light up in the gauges when the lights are on......The fix for that is to add some diodes to cancel the feedback.
Devs93
Shelbyville ,IN
Deven
c1500
snuck this one in while I was typing lol gimme a min to through the whole thread
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
leds dont use low voltage they are low current draw :Big Laugh: but it didnt cause hyperflash for me it caused... no flash! but the new flashers fixed that, only problem i got is alternating with the headlights on.
Devs93
Shelbyville ,IN
Deven
c1500
Ok the diagrasm look correct so lets start with this Im not sure what you mean by electrical flashers you gotta P/N or link? What kinda bulbs are u running 1156/194? Also what brand? Links would be great if available
Devs93
Shelbyville ,IN
Deven
c1500
leds only need low voltage as well I can light most off a 9 volt battery but yes low amp draw etc
Devs93
Shelbyville ,IN
Deven
c1500
ah hell I know what the prob is
They arent HyPer - LEDS :lol:
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
true, once leds are on more voltage doesnt make em brighter. but they are all chinese leds ha. an electronic flasher is just a flasher with a circuit that flashes at a set rate so they are independant from current draw. the stock flashers are thermal so i high current draw heats em up and they flash at a certain temperature. so leds and regular bulbs work the same on the electronic units but dont work on the thermal units. i dont have any links but i know the flasher also says its an led compatible flasher.and yes 196 leds in the sides but 1157 in the front. all bulbs are of the original type but in led fasion. just look up an electronic flasher if ur still confused. the problem im having here is with whatever the mechanism by which the side markers and parklights alternate. haha get what im sayin??
mannybwed
