Blazer Roll Bar
Tmich396
Long Island NY
Tony
Blazer
Hi All, I was wondering if anyone recognizes this roll bar as fitting a K5 Blazer. I’m waiting for some measurements back from the seller, but just interested if someone might see some identifying mounting characteristics.
Thank you!
Craig 85
Nashville, TN
454/TH-400/NP205
78C10BigTen
pennsylvannia
C10 BIG TEN
May be a cj roll bar
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Tmich396
Long Island NY
Tony
Blazer
Hi Craig,
I’m thinking it’s for a later blazer (maybe) because of the way the front mounts look. I’m only guessing but they look like they would mount to the floor and the raised area.
I will try and look-up some CJ pictures as 78c noted it may be from a CJ.
Do the jeeps have a floor that raises up like the later blazers?
Thanks all.
Tmich396
Long Island NY
Tony
Blazer
Ok, well I knew it was too good to be true, this is a CJ Roll Bar. Thanks 78c.
dvdswan
Port Orchard, WA
Dave
Looks like its for a jeep cj or yj as said by 78c10bigten. IIRC the only Blazers that had a roll bar were the 73-75 full top Blazers. They looked like this...
The back portion of this cage I believe is the original...
mounted like this but in front of the rear wheel well... obviously without the lower crossbar.
78C10BigTen
pennsylvannia
C10 BIG TEN
My dad had an early gmc jimmy when i was a child, i remember that part of the roll bar but idr if it had legs coming back or not.
dvdswan
Port Orchard, WA
Dave
Looking at it closer, the part on the wheel well should be on the floor and the other parts on the wheel well.
I've got a factory '73-'75 roll bar I can take some pictures of. That style should fit a '78-later K5 if the front legs are modified to fit the dropped floor.
The late 70's and early 80's K5's could also have an optional rear roll bar. It mounted back by the tailgate.
Misty Blue
