binding problem
chunkyrzr
pellston, Michigan
carl
v2500
Okay i have a binding issue sounds like it is coming from the center of truck. I went and jacked the rear end off the ground and spun tires forward. They went forward freely with no problems. Went to turn them backwards by hand and can barely get them to move. Thought it might be back brakes so i removed the drive shaft and tried again. Everything spins freely. My question is do you thing it is the drive shaft binding, transfer case or transmission. I know it has to be one of the three but which one. Just wondering if anyone else has ever had this issue before and what it was. Also the truck has a 6 inch suspension lift and a 3 inch body lift. Thanks to all of you
chunkyrzr
pellston, Michigan
carl
v2500
400 turbo trans with 208 transfer case. I am getting a binding issue after i drive it 20 miles to work. when i pull into the parking lot and idling into parking spot i get a clunk clunk give it gas and it goes away. Its a weird issue that i have never had or heard of before. it also does it going backwards at idle but only when hot and only at idle, give it gas and it goes away. So today i lifted the truck up turned the rear wheels by hand and can barely get them to move backward, pulled shaft and now they turn freely. i am at a loss as to what this is
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Auto trans will naturally be hard to turn in one direction. Is there a posi or locker in the rear? That's what it is sounding like to me. If it only happens when turning I would say it is a posi binding.
chunkyrzr
pellston, Michigan
carl
v2500
thanks for your help one more question can universals bind after they get hot and cause this. No posi does it going forward at idle and backwards at idle both straight parking spots no turning. this really has me stumped. It just started last week and i can't figure it out.
crazy4offroad
Curt
K-10
350/SM465/NP205
Yes if the u-joints haven't been greased they can bind but usually they just grind the needle bearings into dust and have a lot of slop in them. Is it possible you have auto hubs and they're locked in instead of out?
chunkyrzr
pellston, Michigan
carl
v2500
they are manual hubs and free. i am going to replace the universals and the yoke going into the transfer case. If it is still there or fixed i will reply back. Again thanks for the information
Boone83K10
Boone, NC
Benjamin
my father's 10 bolt had this same issue in his 98 C1500. The spider gears blew out and the axles were floating around inside the tubes. Nothing held them in on the way to the shop!!!
crazy4offroad
Curt
K-10
350/SM465/NP205
Good call, but his front has the hubs unlocked. Although this could be the problem in the rear. Might want to pull the rear cover and check the crosspin.
Driver4r
Nebraska
Trevor
k10,c20
our 91 k2500 has a problem in the rear end where every once in awile(1 every 2 miles or so) where one of the spiders in the rear jumps a tooth, cause one of the spider spacers Is just gone. But it does it at any speed. Usually higher speeds is less often.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
If the spiders were "gone" and "nothing was holding the axles in" the truck wouldn't move. The carrier would just spin on the shafts.
Driver4r
Nebraska
Trevor
k10,c20
unless he is referring to the axle retaining clips.
chunkyrzr
pellston, Michigan
carl
v2500
i won't have the drive shaft done until this weekend. If that doesn't fix it i will check the spider gears in the rear end. Thanks
Boone83K10
Boone, NC
Benjamin
it was the spider gears and the c clips. the c clips went first when he went to back up that morning. On the way to the shop (probably because the axles were floating around) the spider gears exploded. the driveshaft would turn in gear but the truck didn't go anywhere. The tow truck was a good sight to see.
chunkyrzr
pellston, Michigan
carl
v2500
replaced universals and that wasn't it. Took cover off of rear diff everything looks fine. It still does it but only at idle. If you give it gas it goes away. Next thing will be to go between drive and reverse well on jack stands and let it idle and see what happens. Maybe the back brakes are hanging up Who knows. Just thought i would let everyone know i still don't know what this is.
Venison
