Big Block Hood Fitment
1987v10
Hadley MI
Derek
I just had a 496 built for my 87 V10. Will it fit under the stock hood? Or will i need to go with a cowl hood ? I just dropped the truck off at the body shop so I cant set it in there to see. Thanks in advance!!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Of course it will fit. These trucks came from factory with big blocks so no problem. Even the engine mounts will work. You will need to redo your exhaust. Hopefully your running long tube headers. You will also need fresh extra shorts too because the torque you will feel might make your bowels loose.
Your going to also need a bigger rad.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
And we're going to want some pics too, when the truck rolls out of the shop.
1987v10
Hadley MI
Derek
Thank you! I wasn't sure. I have a set of A-body long tubes atm from a buddy that I will "make" work since my fun money is all gone.. I bought the truck 2-3 months ago. Here are the pics thus far.
1987v10
Hadley MI
Derek
1987v10
Hadley MI
Derek
The engine is a 98 Vortec 454 roller cam stroked to a 496. With Eagle forged crank and H-beam rods. Mahle pistons, Howards cam, Brodix Race rite heads. And Brodix intake. Leaning towards a Holley sniper EFI kit to feed it.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Oh **** that's nice!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
That's a bit of a revy intake you have.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Looks good. Your machinist went over that crank right? I have a BB in my 87 V10 I used A-body headers. You may need to notch the frame on the driver side in cylinder 1 tube. I did. I also used solid mounts tho. Do your self a favor put the headers on the engine before you drop it in the frame. Is your front clip going to be on when you put the engine in? Also I had to modify my cross member for oil pan clearance. I can find the pics if you want to see.
1987v10
Hadley MI
Derek
Thanks!! I didn't want to skimp on the build. It will be a torque monster for sure!!
1987v10
Hadley MI
Derek
Honky you actually already sent me the pics in a previous post! thank you! And what do you mean about going over the crank? The standard measurements? ( plastic gauge?) Or something else?
1987v10
Hadley MI
Derek
Shiftpro. Yea I had a duel plane intake initially however I have seen that the Throttle body EFI kits are kind of picky when it comes to Dual vs. Single plane intakes. So that's why I choose that intake.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Eagle cranks can be iffy at best on the factory finished dimensions. And have been known to have out of round journals right out of the box. I'm not hating on your parts just trying to make you aware of possible issues.
1987v10
Hadley MI
Derek
Honky, Thanks My machine shop is a very reputable place I'm sure they did. But since you mention it I will now be asking! And thanks for the (non hater) disclaimer! lol. You have been very helpful on all of my posts that you have responded too. Thanks for contributing!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
:waytogo: I'm not always a sarcastic ***** but I do play one in real life. Lol
sever
