Big Block Exhaust Manifold
71RAT
Deerfield NH
Kirk
K20 Scottsdale
I couldn't wait until I do the rebuild/restoration of my truck. Exhaust leaks were hellacious! The passenger side manifold has seen better days. If I remember correctly, isn't the passenger/right side manifold the same as cars and 2wd vehicles.
fast 99
Spokane, Washington
Have a machine shop grind/sand them flat.
Use high temp orange silicone, no gaskets. Will not leak.
71RAT
Deerfield NH
Kirk
K20 Scottsdale
So you've had success with no crappy gaskets?
I found one with the same casting # for $75.00 with shipping. #8 port doesn't have much material left just above the back bolt. That one already has been resurfaced atleast once.
Thanks
fast 99
Spokane, Washington
Yes, haven't used gaskets on 350 or 454 cast iron manifolds for decades. Have installed a bunch. I can guarantee if you use the gaskets that come in most sets it will leak. The manifolds expand and rip them apart.
Many later engines use a stainless gasket like a LS. Want to use those if they came OEM but still have to make sure the manifold is flat.
Joestreml
