Best way to adjust valves without a torque wrench?
silverscottsk10
trafalgar indiana
mike
Haven't been able to come up with the funds for one of the clicker types after my beam type broke
Have hear that tightening them down to 0 lash and backing off a full turn is an easy way to set them, is this true?
MadOgre
NA
NA
NA
NA
NA
If you get a Haynes manual it will walk you right through the whole process and all you need are some sockets.
That little book is well worth the $25
No, that's wrong. It may be easy, but it's definitely not true. If you did it that way you would have no preload and your valve train would have gaps - and clatter like an SOB.
I think what you heard was, carefully tighten the adjusting nut while twisting the push rod back and forth. When even the slightest resistance is felt to the twisting motion - STOP. You have zero lash.
To set stock preload, continue to tighten the rocker adjusting nut - do not back off. How much to tighten the nut (and pre-load the lifter) is the subject of countless discussions.
But truth be told, however much you decide to preload (1/2 turn, 3/4 turn , a full turn) - it is not that critical. Just be sure that you are consistent and preload all the lifters to the same amount.
The plunger of a properly preloaded lifter should be at approximately the mid-point of it's total available stroke.
As it turns out, 1/2 of the total plunger stroke of a stock lifter is just about equal to the cross-sectional diameter of the retaining circlip.
So, when properly preloaded, the gap between the top of the plunger socket and the bottom of the circlip is equal to the cross-sectional diameter of the circlip. The image below explains better:
Point is, when you are all done preloading you can easily check your work by rotating the engine. As each piston reaches TDC on compression, look down into the top of the lifter and observe the circlip/socket gap. If it is about the same as the thickness of the circlip you are good to go.
350runner
tx
Ceasar
Point is, when you are all done preloading you can easily check your work by rotating the engine. As each piston reaches TDC on compression, look down into the top of the lifter and observe the circlip/socket gap. If it is the same as the thickness of the circlip you are good to go.
x2 on this. this is the proper way small or big cam.
silverscottsk10
trafalgar indiana
mike
Alright
Diesels are a bit different and figured I'd ask
Thanks guys
flatford39
NE Illinois
Tom
K2500
That's usually where I start and then I do it with a vacuum gauge and the engine running. You need to buy those little oil deflectors or you will have oil everywhere.
Another way is to drill holes over the rocker adjusting nuts in the valve cover and use that as your oil shield. I prefer the little clip on deflectors.
MadOgre
NA
NA
NA
NA
NA
Re: Best way to adjust valves without a torque wrench?
350runner is offline Add to 350runner's Reputation Report Post
That X3
You can not set valve lash with your engine running as each valve must be fully seated as you are adjusting the lash, unless your super man and can do it in the time it takes you to blink LOL
nathanjohnson85
