Are crate motors really cheaper?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Yes, thats the one I was looking at a while ago. I thought they suddenly jacked the price WAY up for some reason or discontinued it.
Seeing as your in Pepsiland(reno) you can save freight if they have it in stock at the Summit in Cocacolaville(sparks)
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Haha your going to have to explain pepsiland.
I quickly understood Falabama (Fallon) and Ferntuckey (Fernley).
That Summit retail store is the ****, If I ordered that crate motor I would easily save hundreds.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
In my experience, I would get the engine in Dhamp`s link for $1520...just for easy install, no headaches. And i remember reading that engine actually puts out over 205 when HotRod mag dynoe`d it.
Keep in mind, that $2500 one may have a cam in it for a car, and would no be well suited for a truck, And there`s a 95% chance that the GM block is machined to accept roller cam if you want it.
FYI, stock from the factory, you only had 165hp, and 285 ft lbs @1800 rpm
there's a 0% chance that the block is roller ready... its a 2 piece rear main seal.
Jims86
Patterson,Ca
5.7 TBI
I used to come up there for bowling tournaments, and to go to the air races...Most of the restaurants in reno only served Pepsi.....For Coke, you would have to go to sparks. You could get the 87-95 truck crate, but you would need a later manifold(or modify the center bolt holes) and a new flexplate.....hell, at that point, just get an L31.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I missed Hot August nights so I am going to check out the air races this year if I have time before Tuscon.
Jims86
Patterson,Ca
5.7 TBI
my 86 only replacement crate is roller ready. Thinking about the cam that they use in the HT383.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
my crate was $80 to my door, and if you walk in you'd have to pay ~$90 in sales tax, but you'd also save the handling charge they put on every order. its really going to come out very close... i looked into going to Ohio and picking mine up, and decided to sit on the couch and wait for it.
Jims86
Patterson,Ca
5.7 TBI
My dont think they have sales tax in Nevada.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
and as for the engine being so much cheaper, you're forgetting the added expenses, say you tear into it and find bent rods, or a scored crank. maybe the heads are cracked... or worse the block. it can equal out real quick.
i've got a Ford 200 inline 6 on the stand in my shop right now, that was supposed to be a $1200 rebuild... its over $2000 with unexpected expenses.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
its 6.85% as my research showed
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Complete rotating assembly from Summit- New crank, rods, pistons, rings and bearings for a low price of: 546 bucks.
Complete felpro gasket set with freeze plugs from Rockauto- 58 bucks.
Brand new heads from Summit ready to bolt on- 618 bucks.
Camshaft and lifter kit on rock auto- 128 bucks
Everything new is going to be about the same price as a new crate motor to being with, only exception is more premium components inside.
I guess it would all come down to whats bad inside the engine, if you could re use the rods, crank and rebuild the heads it might be half the price.
The heads are the most expensive so far, how much money does it normally cost to have a pair of heads rebuilt?
^^this....it can add up very quickly with stuff you either don't think about or don't expect to be bad but is. :)
WHEELMAN
HICKORY TAVERN SC
BILL
454 v8
In jegs or sumit.the gm 350 crate motor-is 1650 plus 150 shipping.the dealer might just match that.if you tell the parts guy.you are buying it to install your self.years ago.you could buy the 350v8 at the dealer.for 1250.00 if they know.the shop is going to install it.they will want to charge more.to off set the chiltons labor.make sure you tell them.you want a cash price out the door.they are great motors.brand new..motor..not rebuilt..
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I might just try that, I was looking around the Tuscon craigslist and there was a GM dealer advertising engines for a discount.
60Denais
