AJ 3
- Dec 13, 2013
- Battle Creek MI
- AJ
- C 10
Are 1981 and 1977 Instrument Cluster Wiring the Same as My 1979 truck.
I found a 1977 and 1981 Instrument Cluster and swapped speedometer, fuel gauge, and lighting to build a factory looking cluster with idiot lights. To replace the HACKED "custom" aftermarket not working cheep gauges installed by a PO on my 1979 truck.
Without the Instrument Cluster plugged in all of my exterior lighting and everything else works correctly.
With the cluster plugged in my fuel gauge reads 3/4 tank and the internal and external turn signal lights work correctly.
Everything goes weird when I turn my headlights on. The fuel gauge now reads empty and my gauge lights are very dim and don't change when I turn the headlight knob. My interior turn signal lights also come on and dim when I twist the headlight knob. The interior turn signal lights also now flash opposite of my exterior lights. Also my bright head light blue indicator light is on when my low beam head lights are on but goes out when I switch to brights.
Do I have to search for a working 1979 instrument cluster to solve my issues or do I have something else wrong with my 1979 truck.
