Any GM 2.2 engine experts in readerland?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Last year my son bought a 97 S-10 with the rompin stompin 2.2 engine and a 5 speed. A couple weeks ago, the engine started making some VERY bad sounds, it locked up tight on the drive home.
Over the weekend, I found what is quite possibly the most rusted out 99 S10, also a 2.2 but with an automatic. It runs and drives well, just suffering from a terminal case of tin worm infection.
The plan was to swap engines and scrap what was left. Pretty straightforward, until I had the trucks parked side by side. The 99 engine looks very different than the 97. My local salvage yard shows the engines technically don’t interchange, but isn’t sure what the difference is. Swapping intakes or exhaust is no big deal, but before taking either truck apart I’d like to know what I’m getting into.
I paid 400 bucks for the 99, I figured the 4.10 limited slip rearend and wheels/tires are almost worth that.
Anyone in readerland familiar with these engines? Thanks.
Moderator
Hmm... I used to know the answer to this. But I can't remember. I'm almost positive it was more involved than just an intake and exhaust manifold swap though. I could take some guesses as to the major differences, but memory isn't really good enough for that either. Fairly positive the timing chain setup is different. Maybe. Lol.
78C10BigTen
pennsylvannia
C10 BIG TEN
Why no pics here man?! Lol
78C10BigTen
pennsylvannia
C10 BIG TEN
For someone that "doesn't like" the later S10's, you sure want pictures of them often. You're nuthin but a closet round S10 lover, lol.
Me bein a wheel and tire freak i actually wanted ta see the wheels and tires he said were worth the $400... i dont like the jelly bean style!
Moderator
Whatever you gotta tell yourself! Lol
Bennyt
Surprise
Ben
Its some sensors on the side of the block about middle. Dont remember exactly though. My best friends nephew overheated his late 90's S10 and i installed the new rebuild and was just about done when i figured out there was a knock sensor or ?? not present on the earlier core. Had to pull it all back out and return the new engine and have the original core built. This was over 20 years ago so dont remember exactly.
I would think since you are using a later core into an earlier truck, you might be fine.
Moderator
Crank and/or cam sensors perhaps?
Brianall
