air conditioning condeser
richard
mi
richard
383 stroker
what would the best condenser be for 1986 c 10
yevgenievich
Place
Name
Year
Model
Size
The stock GM condenser (P/N 3053293). This condenser will easily handle the heat transfer load generated by a standard cab under any ambient conditions - certainly those found in MI.
From 1985 -91, that condenser was the only one specified for all series of the GM light truck line. It was over-sized by design. This allowed it to be used with any truck that was fitted with the C60 system (standard under dash mounted) or the C69 system (under dash plus an additional overhead unit). That included all crew cabs, Suburbans and passenger vans.
I have 3 original units laying around - in case the one in use ever fails, but they never do. Unless you poke a hole in one, they seem to last forever.
And, perhaps most importantly, it will drop right in - without any modifications.
Power87
Queen Creek, AZ
Jason
5.7 TBI
I have a 1987 V10 that the AC components were removed. I would like to collect the OEM part numbers if possible! does anyone have that info? I'm looking for Compressor, Hose's, condenser, evaporator, Orifice tube, drier and to top it off I want to stay with R12. Thanks everyone...
richard
mi
richard
383 stroker
after some research there is no such thing as a direct fit condenser sent the retro fit back used stock condenser
yevgenievich
Place
Name
Year
Model
Size
Oem worked fine for me in a single cab truck in texas summer. But for the suburban, the retrofit unit worked a bit better.
Dons79C10
