88-98 steering box brace or weld in?
marks86
Latham, NY
Mark
12v Cummins
do they make one, a 2000chevy has a cracked frame right at the steering box, and they asked me for help
highdesertrange
kalifornia
mike
k30
I am confused. what year is it? highdesertranger
marks86
Latham, NY
Mark
12v Cummins
sorry 2000 classic body style/gmt400
I wasn't aware that GMT400's were having the problem too. If it's a common problem, there's certainly a fix for it somewhere. If it's not common, you'll need to fab something up on own most likely.
Not common at all. Was it wrecked?
marks86
Latham, NY
Mark
12v Cummins
wasn't wrecked it was a plow truck that was never washed and the crack has a crack right by the steering box, I guess I just assumed this was a problem, kinda like our trucks
firebane
Calgary, AB
Curtis
I have owned a few of the gmt trucks and never have I heard of this. I would say if the frame did crack it would be due to the excessive weight on the front of truck or perhaps the plow running into something and twisting the frame?
Is the plow on a 1/2 ton truck by any chance?
marks86
Latham, NY
Mark
12v Cummins
no its a 3500 dump, that was a plow/salter
never washed btw
350runner
tx
Ceasar
I'd fab up something welded :)
farmerchris
southeast kansas
chris
those have the boxed frames,usually pretty strong.on that truck you should be able to groove the crack with a grinder,going to the outside edges to stop the crack,then weld up the groove.use small passes and spread the heat around.then weld a diamond shape gusseting over the cracked area.unless it get in the way of mounting the steering box,then you have to live with welded area and check it periodically.
imyourhuckberry
