Jims86
- Aug 3, 2010
- Patterson,Ca
- Jim
- K10 Suburban Silverado
- 5.7 TBI
ok, 2 things...while it is running, and you are looking at the timing mark with the light, tap on the intake manifold, and see if the mark moves back toward the pointer, and check your TPS voltage at the blue wire with the key on, but engine off...should be around .54 to .70 at closed throttle, the open it, and it should progress smoothly to around 4volts.
