85 K10 4wd relay
Jgonick
West Texas
Joel
I have the wiring diagrams for c10 but they do not have this portion. Can any one tell me where the 4wd relay is. I found the connector hanging by my brake pedal and can't seem to find the relay it plugs into. See image.
Thanks
Jgonick
West Texas
Joel
the pigtail is short so it's got to be close.-- I'm just not seeing it :(
nvrenuf
Mobile, Al.
What year is that diagram?
Jgonick
West Texas
Joel
Not sure- One I found triying to figure out what the hanging connector was. Mine is an 85- The wires are running just like the diagram. I traced them out and that's exactly what mine does-(second green wire splits off father down the line- not at the connector as shown in diagram) I just can't locate where I drew the blue arrow.
nvrenuf
Mobile, Al.
I’ve never seen or heard of a 4wd relay on a square body. The tcases are all mechanically actuated so unless they put a relay on the dash indicator light some had there’s no need for it.
That said 88+ C and K series trucks are a different body style and the 4wds did have an electrically actuated IFS front differential.
Jgonick
West Texas
Joel
It looks like in mainly deal with the TCC for the 700r4. it looks like you need the relay to get current coming from the low vac switch to the A post of the transmission for the temp 4-3 shift. My 4wd indicator light works- but it really never runs through the relay.
Jgonick
West Texas
Joel
Well. I'm not the only one. Here is a guy trying to figure it out 20 years ago.:oops:
Drew about the same conclusions I did. but no real answer.
Jgonick
West Texas
Joel
Just an update on what I've found so far. It is in the wiring diagrams for 84 and 86 (later pages in a square), just missing out of the 85.
K10 trucks with auto MD8 & EGR bleed. I still can't locate the relay in my truck. I can only assume a PO removed it sometime in the past. If anyone has information on the relay itself I would appreciate it. I would like to add it back if possible.
Sort of curious what 4wd has to do with the "open momentarily on 4-3 on shift" for the lockup
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
This is interesting. I have no clue what a 4x4 relay would even do on an 85 other than turn on a light? I could see it on an s10 but not a k10.
nvrenuf
Mobile, Al.
Maybe the acronym or abbreviation is a reference to the transmission's 4th gear operation and the similarity to 4WD = "4 wheel drive" is just coincidental?
Jgonick
West Texas
Joel
@nvrenuf possibly but it is right there with the 4 wd indicator light indicator and transfer case.
I believe the relay opens/close based on the indicator light being illuminated. Putting the transfer case into 4 wheel drive provides grounds to the indicator light (thus illuminating it) and to the relay.
Jgonick
West Texas
Joel
Relay RY31 should work.. -
pole 1 won't be used --
That looks just like the relays GM used on some mid 80's cars for things like fuel pump, MAF power and stuff like that. The TPI engines and the multi-port injected V6's.
aaron06
