84 chevy inline 6
mech
Tn
Sp
C10 with a 2 bbl varajetll rochester carb im needing the vacuum hose diagram for it
South90
Goochland, VA
Josh
Did you ever get the diagram? I am looking for the exact same thing! Same truck and motor!
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
Here is mine from an '81 250 with 4 speed transmission:
Other half of the underhood label:
Probably very similar to an '84, seems to have every type of emission controls of that era. Mine is much simpler now but cracked rubber hoses were the primary problems before. The 3 letter code in the upper left corner (ACR) denotes a specific diagram and system, there are probably an awful lot of them.
South90
Goochland, VA
Josh
Awesome thank you! When I popped the hood of mine it looks like a 80 legged octopus, and it throws my ocd brain way off! What did you do to make it simpler?
Carb'ed Vortec 350
I admit it was daunting when I first got into it on my 81. But, once you get in there, and see the routing, and how each item plays with the other items, you understand why it is like that and it'll be easier on your brain. Yes, the spaghetti bowl of hoses is off putting, but they have a purpose. I actually simplified mine, and it ran okay like that. I left everything in place, just capped off with golf tees, so it was just vacuum advance and the lines from the canister. I had to re-hook it all up for emissions testing, and when I did, that's when I replaced it all, and when I hooked it back up according to the label, it ran better than my simplified setup, and I now run it as the factory set it up, and there is no issues.
Carb'ed Vortec 350
If you go to the Library, just know the links on the first page that show the different applications, the links don't work, you get error message, so just got to the different thread pages until you find the corresponding post number shown in the respective link(s)
Tap the 3 horizontal bars at the top left of your screen. When the page changes,tap forums,when the page changes,tap reference library. That will take you to lots of specific information.
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
Someone posted this in another thread, says it is from an '84 250 with auto trans. Way more stuff that my '81. Hope it helps!
Cletus-33
