82 C10 EFI Conversion project
82SquareBurb
Soddy Daisy TN
Derek
Thanks Count! Yeah I reached out to Holley and Current performance. I guess the universal MPFI harnesses don't use the standard LS style MAP connector, so I need to adapt from the Delphi weather-pack connector to the GM MAP sensor. It's always something! :doh2:
I also ordered up some 3-pin connectors, so worst case I wind up making my own pigtail adapter. One connector holding me up at this point. So frustrating.
82SquareBurb
Soddy Daisy TN
Derek
So far everything is buttoned up, fuel, wiring, most relays, and having connector fun now.
For anyone that might be doing the same swap:
Some fun facts about the Holley "universal MPFI term x max" Holley kit: #550-942 and specifically the universal Harness: 558-104.
The MAP sensor connector on this unit is an odd 3-position weather-pack "green" connector, which only plugs into older 1bar sensors - and no adapters exist as there seems to be no mating female pin connector on earth for the green connector, without modifying some 3-way WP connector to fit. Hence my mismatch above. So running a 3bar MAP requires repining the holley 570-212 connector with an 13519049 - Delphi GT 150 3 Way (or holley's 570-217) to mate to the adapter, or just re-pin a new aptiv/delphi metri-pack connector to plug directly into the sensor.
Also the IAC connector is wired for a Mopar/Holley IAC motor out of the box. To run it with a GM IAC unit, need to swap pins A and C for proper idle control.
Holleys illustration:
So aside from those curveballs, it's been almost plug and play, minus needing the EV14 injector harness and a couple adapters. Fun fun!
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
aside from rewiring the plug, repining the IAC, an entire wire harness, and some adapters you can install it right out of the box!
haha
82SquareBurb
Soddy Daisy TN
Derek
Holley should just rename it the "Close enough kit" :33: I thought for sure Holley would offer an $85 adapter (made out of $2.50 in components) I could duplicate, but nope. Just cut it off is the solution. So be it! lol
82SquareBurb
Soddy Daisy TN
Derek
Just got a reply from Holley, here is the reply: "Use the LS3 Adapter Harness. It will Plug in." So a new connector it is!
NLD79K10
Netherlands
Lars
I've never experienced a "universal EFI harness" to actually be universal, everything I've installed over the years needed some form of modification to tie into an injector set, sensor or IACV.
beast6303
