77 K10 LS Swap
rpcraft
Robert
LS 6.0 364 CID
Oh that is the infmous TAC module? I thought they were more of an inside item? Is that sealed up pretty well?
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Yes. Sealed well. It’s mounted in roughly the same location as it was in the donor truck.
Camar068
Air Force Supporting Member
10 yrs Air Force
yeh mine was in that location as well. I was in a rush and cut the cable going into the cab. Didn't take long to solder them back though.
eskimomann209
Modesto
Marcus
Part of the drive by wire throttle control. Throttle Control Actuator.
I see
I usually use the cable drives for the swap
Wasn’t sure if that was the box for CC
Madhorn
AR-Arkansas
Ken
Was able to finish installing the condenser and test fit the the compressor.
Camar068
10 yrs Air Force
Nice, thanks for the pics. Hopefully be doing this soon.
Madhorn
AR-Arkansas
Ken
As far as the AC part of this project goes, here are some details. When I had the dash apart with the heater box and evaporator removed the heater core and evaporator were replaced when it went back together. This means everything in the AC will be new. Here is rest of the part list. All parts with exception of the belt were ordered from Summit. Belt came from Autozone.
AC bracket ICT 551494x-3
Belt tensioner Continental 49296
Belt 114.3" Duralast 1143k6
AC condenser kit VA 021573
AC hose kit VA 547001
AC compressor VA 047007
AC presser switch VA 11086-vus
rpcraft
Robert
LS 6.0 364 CID
Very nice. I'll probably be doing my VA setup later this year or Spring next year. Goals for now are to get the floor pan on the K5 patched and coated then get all the wiring back in.
Madhorn
AR-Arkansas
Ken
Since the 77 was first started back in September, I have periodically had the opportunity to do running engine scans with a buddy's HPT. The o2 sensors have always thrown codes for heater circuit and back 1 had been running rich. The scan I did yesterday still indicated heater circuit codes but the bank 1 rich condition had cleared up, must have been a sticky injector. Today I installed new o2 sensors and cleared the heater circuit codes. Hopefully this will keep the engine light from coming on.
rpcraft
Robert
LS 6.0 364 CID
Do you have your o2 sensors pointing upwards by chance?
Camar068
10 yrs Air Force
You've got the rear O2's installed?
rpcraft
Robert
LS 6.0 364 CID
Most LS swaps don't use the rear O2 setup. Doubtful his does. FWIW having the o2 sensors pointed up as much as possible is recommended because otherwise moisture gets in them and fouls them if they are hanging anywhere near horizontal.
Madhorn
AR-Arkansas
Ken
Running just the 2 pre CAT sensors. They are mounted almost straight down on top of the header collector. The moisture issue with o2 sensors makes sense. The sensors I removed were from donor truck which had been in some deep water before being parted out.
Madhorn
AR-Arkansas
Ken
So much for the engine light saying off. Back on when I started it to leave work this afternoon. Have not checked it yet but suspect o2 heater circuit. Even so, it is running a bit better.
rpcraft
Robert
LS 6.0 364 CID
Without having to look back through all your photos just curious where your MAF is installed?
Also did you have your harness done or DIY it?
bajadiver
