77 K10 LS Swap
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
I used some steel straps I found in a scrap bin at work.
roundhouse
atlanta ga
justin
77,78,79,80 ?
I was talking about the shroud extension. It's essential for making sure it draws air properly
For some reason I didnt have to extend the shroud
My fan fit in the right spot
Madhorn
AR-Arkansas
Ken
Did you set the engine forward during your installation??
roundhouse
atlanta ga
justin
77,78,79,80 ?
Now that you mention it I think we did
But we had to for it to clear the firewall so I thought everyone did it
Camar068
10 yrs Air Force
I didn't, but there isn't much clearance lol. 1/2" if i'm lucky lol. I wasn't worried about it.
rpcraft
Robert
LS 6.0 364 CID
a lot of times it depends on the motor mount adapters you use. The ones form Tejas Steelworks put the engine forward about 2 inches, which makes it fit in the shroud properly. On the other end of the engine, i fyou are going from a standard or three speed to a 4l60E I think it balances out, but if you are going from a 700r4 to a 4l60e then you end up sliding the trans cross member up and lengthening your rear driveshaft (and shortening your front if you have a 4x4).
Madhorn
AR-Arkansas
Ken
I had to leave my engine in the
stock location due to the mechanical clutch linkage. That puts the engine close to the firewall.
Madhorn
AR-Arkansas
Ken
Bummer! Found a puddle of coolant under the truck this morning. Water pump is leaking. That's whet I get for not installing a new pump when I put the engine together. Was hoping to get a few miles on it first. Oh well, no big deal. Just sets me back a bit on having the exhaust done.
rpcraft
Robert
LS 6.0 364 CID
LOL, i had considered whether or not to do it and I went ahead and picked up a new water pump. I figure it is cheap insurance. they sell one that is preloaded with a new thermostat from Gates for 68 bucks on Amazon. I'm sure any parts store will have that same item. Gates # was 45005, otherwise there is an AC delco pump but I think it was 30 bucks more last time I looked. I'm thinking maybe about a new starter too but from what I read most guys that try new car parts units have them crap out and end up getting better replacement's from the salvage yards.
Madhorn
AR-Arkansas
Ken
My short term exhaust fix is dual straight pipes dumping just behind the rear axle. It will work for now. My youngest son wanted to go for a drive, so we went to our deer lease 5 miles from home. He is getting pretty good with the manual trans. Picked up a water pump today. Will install it later this week.
Madhorn
AR-Arkansas
Ken
Is anyone using an HP tuner set up? I am considering getting one. Never seen one used in person. Are they difficult to use?
rpcraft
Robert
LS 6.0 364 CID
Not yet but I know at some point I will be doing another swap and more than likely I'll pick up a setup for tuning my rig and the next project as well.
Madhorn
AR-Arkansas
Ken
Right now I am running with stock tune from the donor vehicle. Seems to be running ok. But I am wondering how long I can go before I should get it tuned.
rpcraft
Robert
LS 6.0 364 CID
A stock tune is probably going to be very safe, meaning it will run rich so you don't burn anything up or kill any sensors. That being said it's not going to offer the best economy or performance, but it should get you home and back fine if you are daily driving. If you are running a stage 1 or higher cam you probably are not going to benefit nearly as much as getting a good dyno tune, or access to someone that can street tune it, but at the end of the day I'd save a few hundred up and plan a visit to a good tuner.
The stock tune should be adequate for you to test drive and trouble shoot things as you find them as well, then the dyno tune is kind of like the icing on the cake!
twitch1989
