73 K10 Seats
TJ805
Ventura County
TJ
Hi, I'm so cramped against the steering wheel. I'm wondering what seats work for conversion. Has anyone had any luck with swap-outs from other models or aftermarket? Hoping to get something from the junkyard...
-Thanks, TJ
dvdswan
Port Orchard, WA
Dave
Is the seat track froze or corroded up enough that it won't go back to the furthest point? Are there items behind the seat blocking it from going back? Do you have a tilt steering column?
TJ805
Ventura County
TJ
It's tight no matter what and no tilt. I will be looking into tilt as well. Gonna try to get every fraction I can...
hoagster
California
K10, 1500
5.3l
dvdswan, had a good point! I'm a big guy, but that being said I had to reach under the seat and pull on the cable to release the opposite in order to move the seat.
eskimomann209
Modesto
Marcus
6’ and about 270 I feel good about eating a healthy meal and cruising home in the truck
hoagster
California
K10, 1500
5.3l
Little more gut room
Were did you get those, or what vehicle did they come out of, and mounting hardware compatible with stock mounting holes?
The tilt column gives more room than a standard column. Not because of the tilt feature, but because they seem to be shorter.
eskimomann209
Modesto
Marcus
I got them out of a 2016 Tahoe
I adapted my brackets onto the seats and used a little frame to attach the two seats together
eskimomann209
Modesto
Marcus
So I ended up cutting off that c channel
It was more of a tacked welding brace but here’s my little frame I made
And it’s the second row from a 2016 Tahoe
I kinda wished it had a flop down arm rest but I’ll survive
I have one of those ole igloo console things
eskimomann209
Modesto
Marcus
Also thinking I might either have the head rests removed or have the Chevy logo stitched into them
benn95
