700r4 tv cable adjustment
TJones
Santa Rosa, CA
Timm
k2500
I have a 1983 k2500 with a 700r4. I had the tranny rebuilt by a local shop and when driving away something seemed off with the shifting. Took it back and they put a new tv cable on it. Pick it back up and something again seems like it’s not right. It shifts into second about 10mph but all other gears after that feel normal. They double checked the cable and said everything is adjusted correctly but I just don’t feel right about it. They drove it and said it’s operating normally. It’s a reputable shop that I know a lot of people have gone to and is trusted but something is just off I feel. Can anyone look at this cable and offer any advice? I feel the cable should be tighter but looks like they also have the ratcheting option adjusted all the way tight
You need gauges to check adjustment. A lot of people use the set it too tight step on the pedal and it's adjusted method then tighten or loosen it a little to adjust shift points. I don't trust it.
TJones
Santa Rosa, CA
Timm
k2500
I’m just really worried about burning up the tranny especially shifting that quick out of 1st. The other gears seem to shift at the correct points. I don’t have a gauge to measure the line pressure just didn’t know if I should be worried about how fast it shifts out of 1st
I use gauges because I don't want to burn up transmissions. Make sure you get a warranty,let the shop adjust it and leave it alone. You don't want them to void your warranty because you disagree with their setup.
TJones
Santa Rosa, CA
Timm
k2500
Yeah that’s what I have been telling myself it just is a bummer to not feel comfortable driving it because of how it shifts it’s almost more annoying than anything from what I’m used to
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
As long as it goes into each gear with a solid thud (no slipping/sliding greasy, slide into gear) shifting too early won’t really hurt anything.
There are probably hundreds of different spring/valves/govenor combinations HydraMatic used to get the shift points right for each application. That’s sometimes an issue with transplanted transmission swaps, if the donor trans came from a completely different application, it might shift less than desirable.
TransGo offers a calibration kit that includes different springs to help tailor shift points. Transgo Jr 700 I think is the part number.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I stand corrected, it’s called the TransGo system correction kit. It’s pretty involved, but they do work. I had to use one when I put the 700 in my truck, the cop car transmission core I used didn’t work very well when I first installed it.
NickTransmissions
Las Vegas
Nick
I used that kit once, took seemingly forever to get it all installed, lol. IIRC it used to be called the "SK700-SR". I typically install the JR kit and do other things to the VB as needed/required...
Gauges are cheap, smoked transmissions due to TV cable issues are not...Amazon has combo transmission pressure gauge and oil pressure gauge sets available; they can be shipped overnight if you're a Prime member.
If you own a vehicle with a TV-based transmission installed, a trans pressure gauge is a must-have for your tool kit.
silver123
Hope bc
victor
1 and 1/4 to 1/2 inch measured from the front of the throttle should set it near perfect and the cable will not be tight
GTP51
Melbourne Australia
Geoff
R10 Silverado half ton Stepside
Ff your TV cable is set correctly as per the guys that did the reco on the trans, then the next place to explore a said by Matt69OLDs is the govenor , had exactly same issue as you have , rebuilt trans shift points are different etc etc. Changing the springs and weights is relatively easy but fiddly and time consuming even if you do have a lift at home . The Kit has a chart with it as a guide but every trans is different. If possible go back to the trans shop and ask them to either fit your old govenor in your trans or get them to set up the new govenor for you . I presume if something goes wrong and you have played with the govenor springs they may walk away from any warranty.
caincrx
Sedro woolley WA
Caleb
Custom deluxe K10
The cable they installed is a universal cable and it doesn't look like they adjusted it tight enough. Why I say that is because how it's adjusted is by pushing it all the way in and then you open the throttle all the way and the stock TV cable will always be to tight. That's where the auto adjuster cones into play and will Ratchet out how ever much it need to allow full throttle and full TV cable pull. Hold it at full throttle and then push on the TV cable, it should be tight like really tight. If it's not it's to loose. Or buy the right cable for you Vehicle and it will be perfect. And really should have been what the shop put on in the first place. There's no reason to use a fully adjustable universal cable on a stock setup. They are the only way to go with modify stuff where the stock is to short. But they can have issues with slipping and misadjusting and quality and fitment. They can work just fine as well. I'm using one without a issue. But mine won't allow a stock one to work because the stock braket doesn't work because the carb and intake aren't stock and it has a spacer. Any shop I've ever worked at only uses OEM parts unless there not available or the vehicle has been modified so OEM won't work on it. And you can get a oil pressure gauge kit on temp right now for $20 just a thought then you'll know forsure it's right, and you may find it useful for other thing as well.
Nardulli
St Louis
C15
I have found that the best method for TV cable adjustment is to drop the trans pan and observe the lash between the plunger and the actuator arm. At idle, there should be as close to zero lash as possible. At WOT, the plunger should be almost fully "In". absolutely critical. If there is lash at idle position, you will not develop enough pressure and you will smoke the clutches within a few miles.
chevdude
jeff
If you are familiar with the plastic part that goes into the square hole, on the carb mount'.
You will notice that there are little tabs or locks, when pushed in, release the inner cable sleeve that allow it to move independently from the outer part.
Start with the cable moved tight, or towards the rear. Push the tabs to release. Then go full throttle on the carb. The inner part should slide forward when the cable bottoms out.
Release the tabs or locks and you are adjusted.
425HP409
TX
Charles
C10 Short Wide
One thing to make sure happens when you adjust the TV cable is that it will downshift from 2nd to 1st at 20 MPH with full throttle. If it doesn't, you do not have enough throttle pressure. Adjust the cable a little until it does this test.
Broken85
Cumberland, NJ
A
Get a pressure test kit from Amazon. They are like $25. Test it before you even move the truck, specs are attached. It will smoke 700r4 in five miles if you don’t. This is the only “right way” to do this.
  • 700R4 Spec and Test sheet 3.pdf
jw23655
