gwcrim
- Nov 18, 2014
- Ohio
- George
- C10
I'm planning on using a 700R4 in my build. The truck is a 1980 C10. The engine will be a 406 pushing 450-500 HP. Rear end is 3.73 with 26-28 inch tires. I want a 700R4 to keep cost low but have an overdrive.
As I look around at choices, they run anywhere from around $1000 on up. What do I need to look for to make sure I get something that will hold up to a little street hooliganism and a rare trip to the drag strip?
There are no local shops to use. At least none that are known for high performance work.
Are the mail order B&M or TCI pieces worthy?
The Summit/Jegs branded ones?
Gearstar isn't too far away and I'm sure they build a good trans but are they worth the money?
I've always been a 4 speed guy. This is my first slush box. Help!
