700R4 Questions
76K20
Pennsylvania
Alan
K20 Scottsdale
I picked up an 87 700R4 trans, I'm putting it in a 76 K20 with a T350. On the drivers side of the 700 there is a plugin with male connectors I'm guessing for the reverse lights. Can anyone tell me what the plug pattern(for lack of a better description) is? I'm assuming 1 is a power , 1 is for when shifter linkage hits reverse, output current, but the other 2 I have no idea. Thanks for any and all your help.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Im guessing youre looking at the torque convertor lockup connector.
76K20
Pennsylvania
Alan
K20 Scottsdale
Alright now you had to go and throw a wrench in the works. What am I going to have to do for that?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Bowtie overdrive makes wiring kits for hooking it up in a non-ECM controlled vehicle. You can also find them from other makers.
Reverse lights are fed off a switch at on the column.
76K20
Pennsylvania
Alan
K20 Scottsdale
That's what I needed to know, Thanks man.
alwaysbroken
